What CAM software are you exporting too?
The lines and points usually need to be selected in the CAM program and a tool path generating command run on them.
Hi.
I have been watching videos mainly about guitar parts - and the same situation arises from time to time.
eg when marking the holes eg for the control pots or the tuners and indeed for the fret slots - the remark is made " mark the positions with a dot because it's a drilling operation" or for the frets a cutting operation.
OK everything's marked - but how is that info 'exported' and signified for tool pathing?
I'm in the position where the fret lines for the slots don't get exported either by themselves or with the model as a whole.
Can someone enlighten please?
Thanks,
Rob.
- Need Help!- Machining operations
- FERMAT Universal milling machine with turning table-Machining operations with UHA mic
- Need Help!- Two questions about moving geometries and machining operations
- Just IN- Locus CAE … a NEW tool that estimates tolerance consumption for machining operations.
- Rhino Help...Again..Machining an edge curve.
It sounds like you're exporting your models as STL, which only recognizes meshes. If you want linear and point data exported, you'll need to use another format, like IGS or DXF.
It should (although I thought fret slots were straight), but whether Aspire recognizes them is another question. Why don't you try it and let us know?
well...I've been trying lots of stuff ) Here's where my blundering about has lead me - projecting the fret lines onto the surface of the fretboard results in curves which I sort of extruded to give little curved bottom slots. I didn't know rhino would go so low as to do a .023" 'recess'.
There's an argument about flatbottomed fret slots as opposed to curved ones - without getting in to it i figure the curved bottom would be less work for a fine bit since the imperative is to have a set depth at the ends.
So ASpire recognised them but I was always cutting the negatives ie leaving little bits of wood sticking up rather than producing cutouts - when my wife said - 'are you sure you're cutting between the lines?' - which i wasn't - so after all the effort spent cleaning up 22 extrusions to produce beautifully modelled open slots in the fretboard surface i went back and enclosed the ends and exported them by themselves and that seems to work as a separate job.
But I feel there must be a way to simply draw a line and say cut that with a .125" bit (say) to a depth of .1" like i'd do with a router.
Man this modelling is good for the neural networking!!
I think I found a tute on drilling & grouping on the aspire web site.
Probably the neck is more 3d than the guitar body the simpler ones being outlines, and pockets cut to a depth. (Not thinking Arched tops atm) )
Thanks,
Rob.
