Originally Posted by
RandK
I use (or make) a surface in Rhino to transport the geometry and then open the .3dm in SW, start a sketch and use convert entities to get the edge. This way anything I want to use in Rhino such as splines gets to SW just fine. If you need to play with the geometry you can delete all the relations from the converted entity and do as you please, even edit splines. Not sure why that didn't work for you when you extruded. If it's planar geometry, I just use a planar surface as the temporary surface.
