Results 1 to 4 of 4
Thread: Titanium axles
    May 2007
    Titanium axles
    Hi guys,
    I'd like to get a ballpark quote for qty: 10 axles turned from 6AL-4V. Anything along the lines of: XX-YY$ will be sufficient, I just want to see if expanding my business into this field will make sense. If it does, I will make accurate drawings for a final quote. I will provide the material as well.
    The other items that I would need are: qty: 10 rear axles and qty: 10 pivots. These are essentially the same size but minor changes.
    Thick end: 32mm outside, 55mm long
    Thinner end: 25mm
    Metric thread on the end (need to measure)
    Bore: 15.8mm (not critical)
    Total length: 240mm
    There is also a hex cutout for a 24mm Allen key on the side where my hand is. About 25mm deep. (rear axle does not have this)
    Cheers,
    Sebastian
    Feb 2012
    Sent you a PM.
    Regards.
    Mike Schetterer
    Fiinegrain Metalworks
    (425) 681-4732
    May 2007
    Replied.
    Sebastian
    Jul 2012
    China
    Hi ,
    we also can make this .
    gpm_sales03@gpmcn.com
    Brant
  1. Mach3 MPG consolle indipendent axles
    By graziano in forum Mach Wizards, Macros, & Addons
    Last Post: 07-13-2012, 12:14 PM
  2. RFQ: 2x 4130 Normalized Stub Axles, 2x 1018/1020 Milled parts
    By cgwiita in forum RFQ (Request for Quote)
    Last Post: 03-10-2011, 11:15 PM
  3. Removing gearbox axles on an X3
    By Thorpydo in forum Benchtop Machines
    Last Post: 04-30-2009, 01:27 PM
  4. How to make axles nicely perpendicular?
    By Witsenburg in forum Mach Mill
    Last Post: 10-02-2007, 10:46 AM
  5. RFQ - Turned stainless - r/c axles
    By rc-cellar in forum Employment Opportunity
    Last Post: 08-21-2006, 09:54 PM
