Results 1 to 8 of 8
Thread: RFQ- Can anyone make Transmission Shift Collar
    Jan 2009
    Looking some someone to 3D Scan a shift Collar i have and to replicate it if possible, wondering how much a project like that will cost to scan it and produce a piece
    May 2004
    Upload a photo of the part. Include a scale or object of known size in the picture as reference.
    http://www.kirkcon.com/
    Feb 2009
    e-mail me at mike(at)mcpii(dot)com. I can scan it and reverse engineer. May be able to machine it as well, depending on what it looks like. Like the other poster said, put up a photo so people can get an idea of what you are looking to replicate.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jan 2009
    Jan 2009
    I just need the outer collar redone
    May 2004
    And then the dude puts up pictures of a half dozen parts with no scale visible. And says "outer collar", which i guess means the outer planetary gear.
    Jan 2009
    sorry thats all i have now ill grab one tomorrow and do measurements so i can post them on here
    Jan 2005
    vagmaster
    It looks like you need the synchromesh clutch rings, these are forged then machined, some are cast, they are made from aluminum bronze & other engineered bronze material
    They have to be correctly made, or they will not work, a worn out one would be no good to copy
    It would be much cheaper to buy them if you can find them
    Mactec54
    1. Where can I find this clamp on collar?
      By Kingjamez in forum Benchtop Machines
      Last Post: 02-10-2012, 10:18 AM
    2. Need Help!- Erickson Quick Change collar nut stop screw???
      By cabledude in forum Bridgeport and Hardinge Mills
      Last Post: 10-26-2011, 06:33 PM
    3. Replies: 4
      Last Post: 06-02-2011, 04:19 AM
    4. Need A Quote- 1 Small steel screw with collar.
      By diyengineer in forum Employment Opportunity
      Last Post: 04-26-2010, 02:47 AM
    5. Telescopic Tubing Spacing Collar (?)
      By creative_mind in forum Mechanical Calculations/Engineering Design
      Last Post: 11-10-2008, 03:18 PM
