Results 1 to 10 of 10
Thread: RFQ : Simple Aluminum Mold
    Oct 2010
    Thumbs up RFQ : Simple Aluminum Mold
    Hello there,
    I have a simple CAD model (~40mm x ~20mm x ~4mm), destined for injection molding. Before that I would like to obtain a prototype.
    A. Would like a simple aluminum mold to be designed and cut. Here is one possibility I see: Blank , with something like This being an expected result.
    B. I am thinking to use simple Benchtop Injection molder with the mold cut. If you have an access to one, please let me know, and I 'll be glad to use your service as well.
    C. Let me know if you could put together a more complex mold (slides?) for a model with undercuts.
    Thank you for your time,
    Alex
    Jul 2009
    NL
    If it is about the prototype, why not 3D print it?
    Costs next to nothing compared with having a mould made and then have that injected...
    If that is not the look you need, have it printed and then use vacuum casting to get it in different looking material. Can be done with silicone mould, still likely to be cheaper than moulding in Alu and then custom injecting it.
    Just a thought.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Oct 2010
    Quote Originally Posted by CaptainVee View Post
    Sven,
    Thank you for your input. I've already obtained 3D printed prototypes to verify general appearance. It's more of a fit test now. It will be two prototypes that would need to fit together, if that makes sense. It's the matter of 0.01mm precision that is not possible to achieve/verify with 3D printers.
    May 2004
    While it is reasonable to maintain 0.01mm repeatability in injection molding, getting to that first part that has 0.01mm precision usually takes trial and error on the part of the mold builder and the injection molder. Even a small mold is likely to cost 1000's of dollars. Are you prepared to pay 1000's of dollars at this point in your project?
    http://www.kirkcon.com/
    Jan 2005
    putnik
    Slides for undercuts can be done for these small molds,with no problem .010mm .0005 is not so easy to achieve,A Bench top machine this .01mm would be impossible, unless it is computer controlled machine, In a real molding machine you can mold parts with this kind of tolerance only if they have good control (Computer control) on there machines
    Sent a PM
    Mactec54
    May 2004
    putnik
    Slides for undercuts can be done for these small molds,with no problem .010 is easy to achieve, in a real molding machine you can mold parts to .001 & less if they have good controls (Computer control) on there machines
    Bench top machines are hard to achieve part tolerance even the .010 because you don't have much control over the shot size, hold pressure Etc
    Sent a PM
    "in a real molding machine you can mold parts to .001 and less." Precision to +/-0.00003937" and less. Amazing! I would like to know how most people measure 0.00003937". None of my tools read smaller than 0.0001"
    Jan 2005
    txcncman
    Not sure why you have a problem with .001 this is a big number to me I work with .0001 all the time every day
    As you can see the numbers I used before I changed the post were inch not metric I changed the numbers once I saw he was using metric
    Mactec54
    Registered Smertrios's Avatar
    Mar 2005
    I believe I have seen both of those pics on another website as something you can already buy but there is no tolerance callout. Will look now for a URL as I don't recall where it was. Or... your part is different?
    EDIT: your links show the website I was looking for http://www.injectionmolder.net
    EDIT: nevermind I see now your part is a different size
    Oct 2010
    Question
    Quote Originally Posted by txcncman View Post
    Thank you for your input. Based on the quotes for production mold, I know a steel family mold of 8 items will run me anywhere from 5 to 10K. I was hoping that an aluminum mold for single item will be less. But that's why I posted this request to get a realistic prototyp equote. Would you care to look into it?
    Regards,
    Alex
    May 2004
    Mold engineering is just that - engineering. Engineering is just one piece of the cost puzzle. If you do all of your own mold engineering, and just post the drawings of the mold you want to have machined as an RFQ, I am sure several people will bid on it. If you want someone else to do the mold engineering, assuming you have already engineered your part, I am sure you can pay someone to do that too. To keep cost down, the more of the work you do for yourself, the cheaper it will be. I seriously doubt you even have your part engineering correct at this point. You probably have not allowed for draft angles and material shrinkage.
    In W.A.G. terms, I would venture up to 20 hours for mold engineering and another 20 hours to machine the mold. If someone was working for $50.00 per hour, that would be $1000.00 for the mold engineering and another $1000.00 plus material plus shipping for the machining of the mold.
    I hope that helps.
  • Tags for this Thread
