Hello Guys,
Busy developing a process-control node that can be used in industrial environment, based on a Nexcon EBC-500 motherboard.
I have designed a small passive-cooled heatsink, which will bolt to a case with sufficient cooling capabilities.
The heatsink is to be from aluminium, and I would reckon a 1/4mm (0.01") finish should be good enough. I don't care who provides a quotation, USA, EU or APAC based, I will pay for the shipping...I would like single qty pricing as well as quantities of 5 - this is for private use for now, but I may be after huge volume should this prove be sucessfull.
Another thing, I cannot afford 100's of $$ for a single unit, if this is the case, I would have to make another plan.
Herewith a very accurate dxf/dwg AutoCAD file.
Appreciate your quick response.
LinkBack URL
About LinkBacks
