Results 1 to 6 of 6
Thread: RFQ, VERY LARGE "LONG" MILLING/DRILLING
    Mar 2010
    Looking for a shop that can handle this project. Tool steel, aprox. 3/4" thick x 4" wide by 16ft long. 6-parts, requiring precision milling, drilling, and heat treating. Interested parties contact me and I will email dwgs. Thanks, Herman
    Sep 2011
    China
    Hi Herman,
    Please send your drawing to hugo@wizmetal.com
    Thanks.
    Regards
    Hugo
    Jan 2008
    Beaverdam, Virginia USA
    You may want to list your location so someone local can respond. If my quick math is correct your parts are going to weigh 1/2 ton for the lot.
    Mar 2010
    We are Located south of Richmond VA. but will provide freight for parts if sourced to a non-local shop. Regards, Herman
    Mar 2010
    Just found out, parts can be made out of 4140 pre-hard on the rails, and regular 4140 annealed on the carrier, so heat treating is not required.
    Oct 2010
    Please send info to ironman34@msn.com
    1. Making Large "Turner's Cubes" on an Engine Lathe
      By widgitmaster in forum General Metalwork Discussion
      Last Post: 02-26-2012, 06:23 PM
    2. Need Help!- 4" long 1/2" cutter squeals when cutting and leaves mill marks
      By danvan in forum WoodWorking
      Last Post: 11-06-2011, 05:58 PM
    3. "Creating room for a large size tool" (SMTC)
      By l u k e in forum Haas Mills
      Last Post: 10-11-2010, 01:15 PM
    4. Need Help!- Thread Milling using "C" axis no "Y" on the machine
      By tejano4life72 in forum Mori lathes
      Last Post: 07-19-2010, 03:59 PM
    5. Milling, Drilling and Tapping .75" Thick Fiberglass...
      By Cyre in forum Glass, Plastic and Stone
      Last Post: 10-26-2007, 12:39 PM
