Results 1 to 2 of 2
Thread: RFQ turned steel rod, easy job
    Jan 2012
    belgium
    Need 2 of these rods turned in (preferably carbon) steel, CNC or manually.
    The fillet at the end doesn't have to be precise, but the tip has to be rounded.
    The rod diameter tolerances are 15.95mm+/-0.05mm and 7.95mm+/-0.05mm.
    Registered cncspec.com's Avatar
    Dec 2010
    PM sent
    Sam
    Cncspec.com
  1. 1.5" Dia Part turned from Steel w/ flats - Qty of 100
    By yantra3d in forum RFQ (Request for Quote)
    Last Post: 05-07-2011, 11:47 PM
  2. Need A Quote- Small Steel Plasma and Turned Pieces
    By clintster442 in forum Employment Opportunity
    Last Post: 01-27-2011, 11:13 AM
  3. RFQ on turned steel parts
    By TheGreenMachine in forum Employment Opportunity
    Last Post: 11-12-2010, 01:15 PM
  4. Quote Awarded RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 04-14-2009, 02:12 AM
  5. RFQ - small mild steel turned and drilled parts
    By mcmmach in forum Employment Opportunity
    Last Post: 07-28-2005, 10:37 PM
