Originally Posted by
jeffrey001
From the compact peep sight assembly, the 2 square cut out where the dial or knob is would be difficult to machine because it has square corner.
For the dovetail at the base, 90 degrees angle is OK but would be easier to machine if height was .125 instead of .110 because of the availability of the cutter which is 1/4 height.
113.68 or 23.68 degrees is not very standard for an angle to be machined, maybe if 30 degrees work for you, would be easier too.
Just my tought.
Jeff
