Results 1 to 3 of 3
Thread: RFQ muzzle brake
    May 2010
    use
    RFQ muzzle brake
    I am looking to have a muzzle break made. I dont know much about machining so there may be some flaws, but this is what i was able to come out with. the only real tolorances are the threads and the bore. The bore can be bigger than what is labeled in there but no smaller. This is not in the design but i would like a small nut made to cover the the exteranal threads. I would like the out side of the knurled. Also please make note that the internal threads are left had thread. I would like out of some kinda stainless steel. and if possible power coated or anodized black.
    Attached Thumbnails Attached Thumbnails RFQ muzzle brake-muzzle_brake.jpg   RFQ muzzle brake-muzzle_brake1.jpg
    Sep 2009
    U.S.A. #1
    What's the overall size of this part and thread specs?
    May 2010
    use
    this should have all the dementions on it.
    Attached Files Attached Files
  1. I need a brake.
    By herring_fish in forum Wooden Clocks
    Last Post: 02-08-2012, 01:31 PM
  2. Need Help!- Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum General Metal Working Machines
    Last Post: 11-21-2011, 10:03 PM
  3. brake
    By rotsenmendoza in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2011, 06:39 PM
  4. New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging,Extrusion...
    Last Post: 09-06-2010, 11:56 AM
  5. Need a box and pan brake
    By J-Mccoin 2009 in forum Want To Buy...Need help!
    Last Post: 12-11-2009, 04:10 PM
