Results 1 to 6 of 6
Thread: RFQ: thermal block for 3d printer hotend
    May 2011
    Small SS block with a central core and several metric screw holes. See attached file. Would like quote for five of them. Thanks.
    Attached Files Attached Files
    Jul 2005
    united states
    stainless block
    Is the file you sent in inches and 1 to 1 scale? Not sure of the dimensions I am getting are correct.
    May 2011
    Sorry about that ... units are in mm unless noted otherwise. Drawing does not print to scale 1:1.
    May 2011
    This order has been closed. That was unexpectedly quick btw.
    Oct 2006
    Just curious as why you are using stainless steel for the thermal block? I plan to build my own printer one day too. Why not use aluminium? If you are worried about corrosion, could you use Nickel to get a higher thermal conductivity rating?
    May 2011
    Good question! Most likely that option will be explored down the road. These pieces are for prototype machines.
    1. Need Help!- thermal alarm on f-20
      By settingbur in forum CNC Swiss Screw Machines
      Last Post: 12-23-2011, 04:24 PM
    2. Converting a laser printer into a 3d laser printer
      By Joćo Carimo in forum General Metal Working Machines
      Last Post: 04-30-2011, 04:56 PM
    3. sl-10 thermal comp
      By shawncnelson in forum Haas Lathes
      Last Post: 07-07-2009, 02:19 PM
    4. Thermal Arc PAK 20a
      By scrambled in forum General Waterjet
      Last Post: 11-01-2008, 10:57 PM
    5. RS232 program block by block
      By smoregrava in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-22-2005, 01:52 AM
