Results 1 to 4 of 4
Thread: RFQ small aluminum standoffs.
    Jan 2011
    us
    Here is the file for the standoffs I am needing. Need 100 to start with.
    Attached Files Attached Files
    Oct 2011
    More info please
    What material? 'Aluminum' is not quite sufficient. Is T6 OK?
    What are the tolerances?
    Can the piece be made from .25 square stock? It would be a lot cheaper that way. Even .25 wide and ~.20 deep -- face off one side of the square -- would bring the complexity and price down a lot.
    How deep is the hole in the bottom?
    Am I correct to assume that the point is two flats, parallel to the two sides?
    Jim Hurlburt
    Yakima, WA
    Jan 2011
    us
    Quote Originally Posted by jimhurlburt View Post
    What material? 'Aluminum' is not quite sufficient. Is T6 OK? yes
    What are the tolerances?.005
    Can the piece be made from .25 square stock? It would be a lot cheaper that way. Even .25 wide and ~.20 deep -- face off one side of the square -- would bring the complexity and price down a lot. yes
    How deep is the hole in the bottom? .200
    yes
    Jim Hurlburt
    Yakima, WA
    Jan 2011
    us
    Job awarded. Thanks for the quotes
  1. Looking for Stepper Standoffs
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 11-15-2010, 11:46 AM
  2. Quick and easy board standoffs
    By ger21 in forum General Electronics Discussion
    Last Post: 08-15-2010, 06:35 PM
  3. Small aluminum tool
    By stevehuckss396 in forum Employment Opportunity
    Last Post: 03-10-2008, 10:16 PM
  4. RFQ for 120QTY 5/8" Round Stock Standoffs 6061 Aluminum
    By mpstech in forum Employment Opportunity
    Last Post: 09-20-2006, 04:02 PM
  5. contouring aluminum with small bit
    By corpse in forum Benchtop Machines
    Last Post: 09-14-2004, 02:11 PM
