Results 1 to 4 of 4
Thread: Wire EDM work
    Dec 2009
    Wire EDM work
    I need an assembly machined out of heat treated S-7 tool steel using wire EDM. The assembly is under 70mm in total diameter. One assembly consists of one outer ring, one inner ring, and 8 connecting pawls. Assembly is 7.5mm thick.
    I have CAD files for all components and can provide engineering drawings with tolerances.
    Initial run would be 6-10 assemblies, with 100 assembles as a second order if all goes well.
    Thanks,
    Rus
    Aug 2010
    U.S.A.
    I thought you already found someone to make these? What happened?
    Apr 2010
    If you still need a quote send cad files to edmwire@verizon.net
    Jun 2010
    U.S.A.
    Jason.trusty@us.interplex.com
    We can get that together for ya. Send me the info.
    sent from EVO 3D mobile
  1. What is the best CAM software for wire EDM work
    By Lumenium in forum General Waterjet
    Last Post: 11-28-2011, 04:09 AM
  2. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum General Waterjet
    Last Post: 01-26-2011, 04:47 AM
  3. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 05:34 PM
  4. RFQ Wire EDM work
    By jime in forum Employment Opportunity
    Last Post: 06-08-2007, 09:54 AM
  5. dave, How is 23-200-DS8 Unipolar Stepper 8 wire work?
    By cjchands in forum Hobbycnc (Products)
    Last Post: 10-16-2006, 12:37 AM
