Results 1 to 3 of 3
Thread: cnc routing in 1/4" and 1/2" clear and black acrylic
    Nov 2011
    I need a quote on some parts, i have roughly 50 different parts i need quoted, i have all drawings in dwg format drawn on autodesk inventor. I will have you run a full 4x8 sheet of parts at a time to make it the most cost effective. The last drawing 4inchmediatraylowflow is made with 1/4" clear acrylic the others are 1/2" black. the 1/4" pieces i need quoted per 20.
    If you notice the 4inchtubeflange is a double sided part with an oring groove machined into it.
    Contact me via email @
    james.brokman@hotmail.com
    Attached Files Attached Files
    Nov 2011
    to view these you may have to download the dwg true view 2012 from autodesk
    Feb 2008
    Quote Originally Posted by jimmyjames1981 View Post
    I can open them just fine with VCarve, dimensions and all. I Will pm you with quote.
  1. Replies: 0
    Last Post: 10-24-2011, 06:20 AM
  2. Replies: 0
    Last Post: 06-27-2011, 02:20 PM
  3. (854)POLYCARBONATE CLEAR 1/4" THICK 24" X 48"
    By CNCadmin in forum EBAY ADS
    Last Post: 05-03-2011, 08:10 PM
  4. (855) POLYCARBONATE CLEAR 3/8"THICK 24"X 48"
    Last Post: 04-18-2011, 02:20 PM
  5. Need A Quote- Small batch of Acrylic 80mm-diameter "rings" needed
    By theorie in forum Employment Opportunity
    Last Post: 03-02-2011, 03:47 PM
