Results 1 to 3 of 3
Thread: Delrin Blank machining RFQ
    Registered zcases's Avatar
    Apr 2005
    I wonder if any of you can do this more efficiently than I can....just so slow bandsawing these blanks out......
    I need 1.5" x 6" bars of 3/4" or 5/8" thick black Delrin or Acetal that I will subsequently machine parts from. Tolerances are +/- .050 on the length and width. However, the long sides just need to be parallel enough, and without burrs, to grab in a vice. Thickness should be ok as is from a standard 3/4" OR 5/8" thick sheet or whatever your cutting from.
    Please quote with shipping to zip 13862 for 100 to 200 of these at a time, whatever qty fits your sheet size (for example a 2' x 4' sheet will yield ~128 pcs). If you see a more efficient quantity due to how you nest them in a sheet let me know, I can up the quantity if it helps price. I have a real cost sensitive part and the quantity will be going up, this will repeat.
    It may work best to reply to scase <at] scpconcepts dot com
    Scott
    Last edited by zcases; 11-24-2011 at 12:31 PM. Reason: allow option for 3/4 OR 5/8 material
    http://www.scpconcepts.com
    Apr 2005
    Paradise, Ca, USA
    Call Boedeker plastics and have them quote you the material, cut to size and shipped. Excellent service and I've always had quality product from them.
    Apr 2004
    BC, Canada
    usually plastic suppliers can cut to size...
    table saw works good to with a carbide tipped blade
  1. Machining Acetal/Delrin guides
    By PMOrthotics in forum Glass, Plastic and Stone
    Last Post: 03-05-2011, 09:09 PM
  2. Help With Machining Delrin
    By sparkymeller in forum General Metalwork Discussion
    Last Post: 09-09-2009, 01:52 AM
  3. Need A Quote- RFQ Small delrin part suitable for cnc machining
    By rodjava in forum Employment Opportunity
    Last Post: 07-25-2009, 05:27 AM
  4. Problem- Machining Delrin
    By KonradyTom in forum General Material Machining Solutions
    Last Post: 12-24-2008, 12:15 PM
  5. Need Help!- Newbie Looking For Cheap Machining (Alum/Delrin)Done (I Live in Japan)
    By TheHeadHunter in forum Parts for Radio Control Models
    Last Post: 06-12-2008, 11:45 AM
