Results 1 to 12 of 12
Thread: RFQ: Small Aluminum parts
    Apr 2009
    Just submitted 17 parts to FirstCut.com. They are probably going to be very expensive.
    There are actually 18 parts, one is turned, which they can't do.
    Requirements:
    CNC Mill
    CNC Lathe
    Debur/Bead-blast/Tumbler deburring (almost any approach will work for these parts)
    Anodizing
    Laser marking
    Work directly from SolidWorks files (I hate doing prints unless I absolutely have to).
    Tolerances are not tight.
    Several of the parts consist of drilling and tapping flat stock after cutting to size/shape.
    One of the parts is a 16 inch long picatinny rail profile with a few holes drilled/tapped. No recoil slots.
    There are a couple of parts that have a little more machining work.
    One round steel shaft (drill stock) cut to length, grooved for a retaining ring, chamfered and one flat cut for setscrew.
    Another round part starts as a 1 inch nominal aluminum rod, cut to 6 in length, drill-tap both ends, chamfer.
    The point is that all the parts are pretty simple.
    I need to prototype this design and then look into making a small run (10 to 25 sets). Following that we'd be looking at 100 to 1,000 sets at a time. Not sure yet.
    PM if interested.
    Aug 2006
    Please send SolidWorks files to briscoe_machining@hotmail.com
    Brad
    Nov 2011
    U.S.A.
    Could you please send me the files to look at (adam@moderncnc.com).
    Apr 2004
    BC, Canada
    we be interested in quoting this package to.
    (phil@tddinc.com)
    thanks
    Registered pete from TN's Avatar
    Apr 2007
    RFQ...
    PM sent...peace
    Pete
    Nov 2011
    Everett, WA USA
    Please send solidworks files to jerryt@askogroup.com
    Apr 2009
    Thanks for all the replies (except for the clueless Chinese dude).
    Sending files to those interested.
    Apr 2009
    Can someone really be this clueless?
    Quote Originally Posted by eddiecnc1 View Post
    We Tengzhou Good CNC Machine Co., Ltd. has been a professional supplier and manufacturer cnc machine from China,Products: mini CNC DIY CNC Low cost CNC Small CNC Desktop CNC Milling CNC Benctop CNC CNC Machine Machine tool CNC machining CNC milling Conventional milling Universal milling CNC machine CNC mchine center,keen type machine, CNC machine, CNC Machine Tools, DIY CNC VMC Series milling machine.If you have any needs, just feel free to contact us by eddiecnc(at)163;com goodmc1(at)good-mc.com TEL00866325555900 FAX00866325658466 MOB008618266092311 or shuimuxin@hotmail.com goodmc1@good-mc.com
    Nov 2010
    China
    I would also be interested
    Please send me the files if you have not already been satisfied with the prices you are being quoted.
    Manufacturers of ballistic resistant, explosion resistant and impact resistant materials
    http://www.mingduntech.com/Mingdun.html
    Mar 2011
    PM Sent. Thanks
    Nov 2011
    RFQ
    Please send SolidWorks files to: brian.lee@wilsontool.com
    We would be interested in quoting this.
    Regards,
    Brian
    Nov 2011
    China
    information corner
    Boorish
    Quote Originally Posted by martin_05 View Post
    1. RFQ - 200 small aluminum parts
      By 98vert in forum RFQ (Request for Quote)
      Last Post: 03-26-2011, 05:38 PM
    2. RFQ - small aluminum parts
      By JudgeNick in forum RFQ (Request for Quote)
      Last Post: 03-25-2011, 12:59 PM
    3. Need A Quote- small aluminum parts
      By jeremy0203 in forum Employment Opportunity
      Last Post: 10-12-2010, 08:45 AM
    4. Need A Quote- Small Run CNC Aluminum Parts
      By m7king in forum Employment Opportunity
      Last Post: 04-17-2010, 09:57 PM
    5. RFQ - Aluminum Parts - small job
      By F500 in forum Employment Opportunity
      Last Post: 06-08-2007, 04:30 PM
