What are the tolerances on this? I can probably machine these for you if you are not needing NASA precision. Will you be providing the material or do we source it? Thanks and peace
Pete
Material: aluminum 6061 or comparable
Stock: 1" width .5" thick
Critical dimensions are in red.
I need 6 pieces of 34.5" long or 12 pieces of 17.25".
Prior to commiting to the above I require a 12" sample.
Send me 2 quotes: one for the sample and one for the others.
Thanks.
Pete
Please quote with your material. Online metals has very good prices.
NASA tolerances, lol. I like that. Do you know what they usually are?
I need to press fit something in that slot so: best you can for the keyseat. A key cutter or a bit in good shape should do.
I can adjust for the other dimensions.
Once I get the sample we'll go from there.
PM sent. Thanks
Thank you for your time.
