Description: The guide is used to feed 1/2" x 1" flat stock.
Material: steel.
I can provide step file if you need it.
Edit:
- Please ignore the 5.0018" it should be 5".
- Tolerance for the guide are only important for the slot openings.: 1/2" +- 0.009" and 1" +- 0.012" for width. This are also the tolerances for the stock material.
- I will take care of the tight fit
LinkBack URL
About LinkBacks
