Results 1 to 2 of 2
Thread: RFQ: simple aluminum parts
    Jul 2004
    I would like 3 sets of quotes. The material for each is 6061 aluminum. Delivery approx 30 days. You supply materials.
    Quote 1: Qty:20 of 10.5mm alum easel with the engraved centerline as shown in the drawing.
    Quote 2: Qty:20 of 10.5mm alum easel WITHOUT the engraved centerline as shown in the drawing.
    Quote 3: Qty:20 of 10mm alum easel WITHOUT any engraved centerline. Should be cut from 10mm aluminum stock.
    Please PM with quote, post if you have any questions.
    Thanks.
    -Matt
    Attached Thumbnails Attached Thumbnails RFQ: simple aluminum parts-10.5mm_alum_easel.jpg   RFQ: simple aluminum parts-10.5mm_alum_easel.pdf   RFQ: simple aluminum parts-10mm_alum_easel.jpg   RFQ: simple aluminum parts-10mm_alum_easel.pdf
    Jul 2004
    RFQ closed- thanks for all who replied.
    -Matt
  1. Parts fitting clearances in acrylic and aluminum parts?
    By jbarber in forum General Material Machining Solutions
    Last Post: 11-11-2010, 10:52 PM
  2. RFQ for Simple aluminum Job
    By fastolds in forum Employment Opportunity
    Last Post: 09-21-2010, 09:58 AM
  3. Need A Quote- RFQQuote for few simple parts (Aluminum)
    By rschwarz in forum Employment Opportunity
    Last Post: 05-26-2010, 10:24 PM
  4. RFQ for simple aluminum job
    Last Post: 05-26-2008, 10:04 PM
  5. RFQ: simple parts needed to be built out of aluminum
    By 50062040 in forum Employment Opportunity
    Last Post: 06-06-2006, 06:47 PM
