I'd like to get a quote for 10 pieces of this adapter design.
The overall size of each block is 94mm x 87mm x 16mm. The bolt holes are M6, perpendicular to the front face. The rear face is at an angle, with a protrusion around the 12mm hole. This can be left off if it's too difficult to machine or raises the cost quite a bit. The fillets don't need to be a specific size, they are only there to indicate that a sharp corner is not necessary. The center cutout is parallel to the angled back, the center hole is perpendicular to the angled back also. Material choice would be 6061 Aluminum. I noticed tolerance requests, so I'm appending that hole locations are important but the remaining features could have up to +/- 0.5mm.
I can also provide other file types - whatever SolidWorks2010 can spit out. This is my first SW piece so please let me know if the information in the file is not adequate.
http://www.imaginehow.com/photogallery/adapter_f.IGS
Thank you,
Tobias
