- 6061 aluminum
- 1"x1"x36"
- Will drop ship material unless you can source local
- No chatter in surface finish
- Tolerances aren't critical, .01" is fine.
- Use of 1/8" ball mill is acceptable
- Quantity: 1
- Geometry is finalized
I'm trying to get this done fairly cheaply. Either I can drive three hours to a shop to do it myself, or farm it out. The part is very simple and is a one setup piece. I can even provide the Gcode if you would like.
Proud owner of a Series II Bridgeport.
