Results 1 to 7 of 7
Thread: RFQ - Short Run Pool Cue Holder
    Aug 2011
    I'm looking for a manufacturing company that can produce aprox 1,000 units of a 2 piece metallic pool cue holder. The device's pieces measure about 4"x3"1/2" and 4"x1 1/2"x1/2". Our original prototype was created using aluminum and we'd like to continue using it.
    The one of the two pieces needs a threaded hole drilled in it so that we can add a screw/hook through it. Finally, the outer perimeter of one of the pieces needs to be surrounded with a thin rubber.
    Ideally, I'm looking for a manufacturer that can provide a comprehensive solution for doing every element of production. It's not a deal breaker though.
    As far as the manufacturing process goes, we've gotten quotes for die casting that were way above what we're willing to spend on a device with an unproven track record. I'm looking a solution that gives us a quality product with a minimal cost (isn't everybody?)
    I have set up a special website for our prospective manufacturers so that they can see images of the device, read full specs, etc. Please email me directly at CarletonTorpin <AT> Gmail <DOT> com and I can send you the link. Obnoxious email formatting, I know but I work hard to keep my email spam free.
    This is a product I want to start production on very shortly. Like all consumer goods, the Holiday season is an important time and this needs to be available by then.
    Last edited by CarletonTorpin; 08-22-2011 at 12:49 PM. Reason: Photo was too large
    Apr 2005
    Paradise, Ca, USA
    Please post your target price. If die casting was too expensive, you just might have priced yourself out of the market.
    Aug 2011
    Thanks for the Reply Matt,
    The quote I got for die casting was $10,000 to make a mold plus $20 per unit. That is too much of an investment at this point. $20 is not an unreasonable price for both pieces but the initial setup costs are prohibitively expensive.
    Oct 2008
    poll cue holder
    Hello, Have you found a shop to make your parts? I can not get your emai to work could you please send me a email at skip@utiliscope.com Thanks Skip
    Sep 2011
    Carlton, I could not get the address to work either. Please send info to leroy.jones@jsp.com.
    Jan 2008
    I have an idea for you.
    If you like to call I think I have an idea on making these for you. My number is 715 254 4099.
    Regards,
    Glen Cutcher
    Hawkeye mfg
    Aug 2006
    Sorry you email is not working.
    Can you please send the link to briscoe_machining@hotmail.com
    Thank you.
    Brad
    Briscoe Machining LLC
    614-282-6862
    1. Mach3 for robot pallet pool.
      By engine tech art in forum Mach Wizards, Macros, & Addons
      Last Post: 12-22-2010, 09:16 PM
    2. how short is too short for necks?
      By qotsarock in forum Musical Instrument Design and Construction
      Last Post: 10-26-2010, 11:55 AM
    3. EC-630 Pallet Pool for WESTEC
      By HAILINHAAS in forum Haas Mills
      Last Post: 03-14-2008, 08:18 PM
    4. CAD model of a pool table?
      By dodgem in forum Mechanical Calculations/Engineering Design
      Last Post: 04-26-2006, 07:53 PM
    5. CNC Router for pool cue inlays?
      By Cueman8525 in forum DIY CNC Router Table Machines
      Last Post: 10-20-2004, 10:59 AM
