Results 1 to 4 of 4
Thread: RFQ: Need 18x18x15 inch rigid foam block milled
    Aug 2011
    I need one piece (18”x18”x15” solid) milled from General Plastics FR-7110 rigid polyurethane foam that you provide. Alternative material is acceptable as long it will stand up well to molding with silicone rubber and provide excellent detail. If you recommend a different material I will share that detail with other bidders so they can bid on the same material.
    Pics attached. Tell me what format you want.
    Need by date is flexible. Is 2-3 weeks possible?
    Thanks!
    Attached Files Attached Files
    Aug 2006
    Hello,
    I would like to bid on your project.
    Please send *.IGES files to briscoe_machining@hotmail.com
    Brad
    614-282-6862
    Briscoe Machining LLC
    6862 Clymer Drive
    Reynoldsburg Ohio 43068
    Feb 2006
    Ted,
    The project seems to be right up our alley. We machine many sight models, foundry patterns, and tooling aids from rigid foam, wood, and other materials. Unfortunately, our shop is booked until mid to late September so we would not be able to accomodate your 2-3 week request.
    If you can handle a longer delivery, please send IGES, X_Y, or STEP files. Otherwise we would look forward to quoting future projects.
    Thanks,
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    depryor@davidwolfedesign.com
    Aug 2011
    The shape is defined by a mesh. I'm struggling to find a way to convert the data in Rhino and AutoCAD to get you guys a good IGES or STEP file. Let me work on this problem this weekend and update you both on Monday. Thanks for your patience and interest.
  1. Problem- Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Wood Working Tooling
    Last Post: 07-02-2009, 06:38 AM
  2. First milled PCB
    By Jason Marsha in forum PCB milling
    Last Post: 11-18-2008, 09:49 PM
  3. 3D topographical map routered out of foam foam
    By 3Dmap in forum CNC Wire Foam Cutter Machines
    Last Post: 08-25-2007, 08:55 PM
  4. RS232 program block by block
    By smoregrava in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-22-2005, 01:52 AM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 10:27 AM
