Results 1 to 2 of 2
Thread: RFQ: Polyurethane Isolation Bushings
    Jun 2010
    Hey guys. I'm in need of some turned polyurethane bushings. I would prefer a 40-50A durometer, black in color. I was told by a fellow member that once you get into this softer stuff, it requires a bit more prep work to be readily machinable. Let me know what you guys can do!
    The dimensions will go as follows:
    1.250" OD
    .715" total height (.625" at the full 1.25" OD)
    .090" tall "Locator" section at 1.000" OD
    Center Through-Hole bored to .625" ID
    Standard +/-.005" Tolerances are more than fine.
    Quantity for first order will be 20-25 units.
    Feb 2006
    Super95
    For something that soft, you may want to consider casting them.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    depryor@davidwolfedesign.com
  1. machining polyurethane
    By mcmachine in forum General Material Machining Solutions
    Last Post: 02-01-2008, 07:30 PM
  2. Polyurethane
    By rodneydeeeee in forum Product and Manufacturer Announcements
    Last Post: 09-19-2007, 12:37 PM
  3. PCB Trace Isolation - Minimum Track and Isolation
    By ahoodlum in forum General Electronics Discussion
    Last Post: 09-26-2006, 12:02 AM
  4. Polyurethane enamel
    By MrRage in forum General Metal Working Machines
    Last Post: 12-27-2005, 12:03 PM
  5. Machining polyurethane?
    By MrHorsepower in forum Glass, Plastic and Stone
    Last Post: 12-08-2005, 01:27 AM
