Results 1 to 5 of 5
Thread: RFQ: one off, ali, 80mm dia X 75mm long collar, 1/2" thru drilled, split
    Apr 2008
    America
    Hi All,
    Title says it all really. I need an 80mm diameter aluminium cylinder, 75mm long with a 1/2" drilled & reamed hole, slit along its length to act as a collar for a 1/2" tool.
    Ideally you would be located in NC but I guess shipping's not going to be much of an issue from anywhere in the US.
    Please respond to wilson@wilsonlogan.com
    Thanks!
    Aug 2010
    Bob,
    Do you have any Al type in mind? Tolerances? Slit width?
    PMD
    PMD is offline
    Aug 2010
    Bob,
    I sent you an email. Let me know if I can help you out.
    -PMD
    Apr 2008
    America
    Hi All,
    +/- 0.5mm on diameter and +/- 2mm on length.
    Obviously the reamed hole takes care of itself and the slit can be any convenient size.
    Cheers,
    Bob.
    Apr 2008
    America
    Hi All,
    I have accepted an offer from a forum member & this RFQ is now closed.
    Thanks for your interest!
    1. WTB: 18" diameter .125~ wall stainless tubing, 18" long piece
      By m-134b in forum Want To Buy...Need help!
      Last Post: 11-01-2012, 01:20 AM
    2. Need A Quote- Small batch of Acrylic 80mm-diameter "rings" needed
      By theorie in forum Employment Opportunity
      Last Post: 03-02-2011, 03:47 PM
    3. Need Help!- Drilling 75mm
      By grf in forum General Metalwork Discussion
      Last Post: 01-05-2010, 03:23 PM
    4. New Machine Build- Vac forming ABS 10foot long x 2"x1" chanel
      By fencer in forum Vacuum forming, Thermoforming Etc
      Last Post: 04-22-2008, 12:09 PM
    5. RFQ: 1" Steel Round Drilled on lathe
      By js530 in forum Employment Opportunity
      Last Post: 06-24-2006, 11:11 PM
