pm sent
I am Looking to augment my current machinist with as second to Machine parts that I am already having manufactured, mostly due to constraints my current machinists appears to have.
The cases are a two piece that connect in four corners around an electrical device, the total case size is 2.5 X 4.5 X 1/2 inch. On each side there will be a plastic patterned insert that needs to be machined and attached to the case when the aluminum is bolted together with hex Bolts. Each aluminum piece is currently finished with a vibe machine through media to a satin smooth finish to remove the machine marks. The parts will then need to be anodized with multiple colors.
Designs being used by my current machinist is in Solidworks. I can forward some detailed photos for Cost and Quotations.
I am located in Virginia (Northern) and would prefer a machinist close by so that I can go onsite, but I am open to a remote machinist as that's what i currently have.
PM me if interested and we can go from there.
pm sent
pm sent
BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS
