Just one of each? And what kind of location tolerance are you needing on EACH END of the .154/.159 hole?
I need these two parts made out of aluminum. All surfaces can have machining marks accept for the side with the large hole. For this surface grinding or a finish pass with an endmill will be fine. Here are drawings in IGS and IPT. I may be able to provide different formats if needed.
Part: Top
Material: Aluminum any type
Block Dimension: 3x3x1.25" roughly
Hole Diameter: 1.080" + .005" or - .005"
Hole Depth: .65" + .050" - .000"
Small Hole Diameter: .154" to .159" (#21 to #23 bit)
Small Hole Depth: all the way through
Part: Bottom
Shallow Hole Diameter: 1.800" + .010" or - .000"
Shallow Hole Depth: .025 + .005" or - .005"
Hole Diameter: 1.250" + .020" or - .000"
Top
Bottom
Matt its not very critical. The hole is for a heating element so as long as its round it will work.
Great, but what is the quantity you need of each part?
I need one of each.
Can you send a PDF of the part to csfabworks@gmail.com
Shane
Thanks guys I have someone working on this now.
