Results 1 to 4 of 4
Thread: RFQ: Four Piece Aluminum Assembly
    May 2011
    Plan is for 10 units with a first article inspection if possible.
    Largest piece is approximately 2" x 2" x 10".
    I currently have the 2D drawings out for 3D modeling. Sub can provide SolidWorks 2007, 2008, 2010, Pro Engineer Wildfire 2 or Wildfire 4.
    What format would you like to have for quoting?
    What tolerances should be called out for 2 items that nest but need to slide or rotate? Picture a shaft in a bearing or pin in a race.
    Manufacturer will have input for final revision to maximize manufacturability.
    Files will be available once I get a feel for the desired format and 3D modeling is complete. Estimated in less than a week.
    Thanks,
    John
    May 2006
    more detail will be needed
    Post an IGES for everyone to see.
    Been doing this too long
    Apr 2005
    Paradise, Ca, USA
    John, if you leave it up to the individual, you'll be sending out 10 different file formats which is ridiculous. Pick a couple and go with that. Using software-specific formats isn't really a good idea because 1) it is extremely limiting to whom can open them and 2) will let the shop have access to the feature history of the part, making it easy to change accidentally. If I were you, I'd offer .igs, .sat, and .x_t.
    You will also be well served to provide 2D prints with all notes, tolerances, etc. on them. These are usually provided as a .pdf. Without this, if you have to reject parts, how will anyone know if the parts were actually within tolerance? There's no tolerances on 3D models.
    You need to come up with your own tolerances. Nobody knows your design criteria better than you do. Make the tolerances as wide as possible while still retaining functionality to reduce prices.
    May 2011
    Matt,
    Excellent. That's a fantastic help.
    Thanks,
    John
  1. RFQ: Small aluminum piece
    By grandmasterneil in forum RFQ (Request for Quote)
    Last Post: 03-21-2011, 07:33 AM
  2. Need A Quote- Flat aluminum piece near Edmonton AB
    By youngjim in forum Employment Opportunity
    Last Post: 09-03-2009, 02:41 AM
  3. Need A Quote- Aluminum Piece
    By Bartsimsonii in forum Employment Opportunity
    Last Post: 08-25-2009, 09:10 PM
  4. Cheap digitizing with aluminum foil and a piece of wire!
    By cjjonesarmory in forum Digitizing and Laser Digitizing
    Last Post: 08-11-2009, 04:15 AM
  5. Need A Quote- Turned aluminum piece
    By raidfibre in forum Employment Opportunity
    Last Post: 02-19-2008, 08:39 AM
