How do we know how big is this part???![]()
We are looking for a quote to cnc machine two halves of a 6061 aluminum mold to make fins. They are like small wings. The surface finish should be smooth enough to ensure that there aren't any machining marks in the finished fins, but we don't need it to be polished. The inside cavity should be about 90cm. Please see jpg and let me know if you have any questions.
Thanks for your interest.
Regards,
Chris
The part is roughly 35" x 7.5" x .5"
Regards,
Chris
Chris,
That is a perfect size for our machining capacity. Please email your 3D data, your contact information, and any other production requirements to info@davidwolfedesign.com
Thanks,
Doug Pryor
David Wolfe Design, Inc.
Akron, OH
www.davidwolfedesign.com
depryor@davidwolfedesign.com
Contact: Schletha at Specialty Fabrication Inc (SFI). Our WaterJet Cutting Machine can accomindate your Metal Cutting Needs. Let Us! Send you order by FAX: (316) 2640606 or Email your drawings to duanem@specialtfab.com and we will start as soon as possible. Thank You!!!!!
SCHLETHA
Water jet a mold, very very doubt full. There are water jets that could definately reduce the time in making a mold, but it still would have to be finished via machining. The dumbest thing of all is, this thing is a aluminum mold, no need just machine it from begining to end. I can see if it were pre hardened steel, but this is far from the case.
