Results 1 to 7 of 7
Thread: RFQ-simple aluminum sleeve
    Mar 2005
    Looking for a quote for the part on the attached PDF.
    It is a simple aluminum drill sleeve. The only critical dim is the outside diameter. The part must pass thru a "Q" (.332") size drilled hole. The inside diameter is simply a snug fit for a #19 (.166") drill. We can squeeze the sleeve to snug it up on the drill bit if needed.
    Please quote quantities of 50 and 100.
    Attached Thumbnails Attached Thumbnails RFQ-simple aluminum sleeve-dril_sleeve.pdf
    Aug 2010
    Dpowell,
    What type of Al? 6061?
    Tollerance for the outer diameter at .330 +0.000, -0.005 ?
    Length tollerance 1.50 +/- .01 ?
    Inner diameter drilled with #19? Or do you really want .165 ?
    Any special finish required?
    How soon do you need them?
    Regards,
    ABC
    Mar 2005
    ABC,
    6061 would be would work well and give us a little wear resistance.
    The tolerances you have shown would be fine. Drilling the ID with a #19 would be fine as well.
    These sleeves are going to be used in construction, no special finish required.
    A time frame of 1-2 weeks would be great.
    Aug 2010
    One more question and I am ready to quote. How concentric does the center hole have to be with the outside? How much runout is acceptable?
    Attached Thumbnails Attached Thumbnails RFQ-simple aluminum sleeve-drill_sleeve.jpg
    Mar 2005
    If we could hold run out to .005" or less, that would be great.
    Aug 2010
    Great. I will put a quote in a PM.
    Mar 2005
    Thanks to all for the quotes.
    The job has been awarded.
    1. RFQ for Simple aluminum Job
      By fastolds in forum Employment Opportunity
      Last Post: 09-21-2010, 09:58 AM
    2. Need A Quote- RFQQuote for few simple parts (Aluminum)
      By rschwarz in forum Employment Opportunity
      Last Post: 05-26-2010, 10:24 PM
    3. RFQ for simple aluminum job
      Last Post: 05-26-2008, 10:04 PM
    4. Need A Quote- Simple T6061 Aluminum Frame
      By sleepy23 in forum Employment Opportunity
      Last Post: 05-15-2008, 06:45 AM
    5. Simple Aluminum Part
      By vadimvc in forum Employment Opportunity
      Last Post: 04-30-2007, 04:51 PM
