Hi everyone, I need a hydraulic subplate adapter made up, mild steel. Tolerance to .005, dimensions as per supplied drawing. Two important things, I need this to match a NFPA P06 mounting pattern, and I need it ported on top for a Sun Hydraulics T-2A cartridge valve. If you dont know what these are, then please don't say you can do it. The P06 pattern is easy but the machining for the T-2A cartridge takes some special tools.
I could have this made by one of the big manifold manufacturers but their lead time is terrible right now, I would be looking at about 3 months. If there is a small shop out there that is experienced in manifold machining and have a decent lead time, it would be very helpful.
The drawing is too large for the upload so if you are interested, I will email it to you.
LinkBack URL
About LinkBacks
