- need two custom hubs made
Hi, we are mechanical engineering students at CSU-Sacramento and are participating in the Shell eco marathon competition in the UrbanConcept category. So we are basically building a custom car built to get the best mpg possible. We will be the first team to compete from CSUS.
We are in the need of custom rear hubs for our vehicle. One side needs to have a 1-inch diameter with a 1/4" key slot. The other hub needs to be free so we will need one that can fit two bearings (one on each end of the hub). The bearing we are looking at for this set up is 1"-ID (diameter of drive shaft) and 2"-OD, but we can change bearing outer diameter size if needed as long as it's a standard bearing size easily available in the market.
Will need a custom 5 bolt pattern (smaller then vehicle 5 bolt patterns). I could get you this info if needed.
Please let me know if this is something you could help us out with and the total cost for the hubs. As I mentioned we are students and on a very tight budget. We are also looking for sponsors as this is a very large national competition, there should be lots national exposure and being the first team to compete from CSUS we are also looking for quite a bit of local exposure also.
Gold Member
Re: need two custom hubs made
I might be interested in making these for you guys depending on the drawings. I can't do it for free but I would not mind some publicity for my small shop out in the world. I currently make parts for the shooting sports guys as well as some parts for tuner cars etc. Always looking for ways to improve my exposure and bring in new work. You can see some of my stuff at my Facebook page A&N Precision Machine. Send me over what you have and I will look at it. Thanks and good luck in the competition...
Pete
Pm me or email
info@chiefmachining.com
We could do this at material cost
- You may not post replies
- You may not edit your posts
Forum Rules
