- Machining Feasibility Test for Candy Company in Birmingham Alabama
Re: Machining Feasibility Test for Candy Company in Birmingham Alabama
I think you might be better off looking at a CNC router with a dust collector. Your inside sharp corners are going to be difficult to machine. Maybe your prototype has been been assembled from pieces joined together? A lot of chisel work required to achieve them if you start from a solid block of material.
Hi and thanks for your suggestion. Yes, the particular part you are looking at was fabricated from pieces which did cause the square corners. I am familiar with 5 axis routers as I operated and programmed a Thermwood machine several years ago. I have a specific design for machining that has fillets on all inside corners. That being said, we are somewhat flexible on the design and can modify as necessary to enhance machinability.
- You may not post replies
- You may not edit your posts
Forum Rules
