Originally Posted by
handlewanker
Hi, without seeing the design it's difficult advising how to improve the sealing at the bottom bearing set.
I would have gone for angular contacts in the conventional spindle configuration with separate seals as is normal......why re-invent the wheel..
Normally you would have a seal in the bearing cap, or a labyrinth seal that is attached to the bottom of the spindle to, keep the bearings and lube in.
Post a sketch of the spindle bearing layout for further evaluation and advice.
BTW....why the heck are you using tapered rollers when the conventional way is to use angular contacts?.......tapered rollers are not all that good for high speed anyway.
Ian.
