Just a heads up, the shim material is about as thin as I'd go for these import disc cutters. Their side wall clearance is right at the point where the shim can become pulled between the cutter and hole. Using a sacrificial piece of sheet metal under the shim stock while cutting could help I believe ( perhaps above it--i can't recall what i read)
Sent from my VS985 4G using Tapatalk
