Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines > Redsail Laser
Redsail Laser Discuss Redsail laser machines etc. here.
Old 01-20-2012, 06:04 AM
REDSAILER is on a distinguished road
Redsail M900 Cutting Performance
Have recently set up new M900 60W Engraver / Cutter from Redsail. Running Easycut 5.3 from XP Windows PC. Mirrors are aligned, lense is focussed BUT the laser cannot cut cleanly through business card stock paper. Have tried all power / speed combinations with poor results. At 60% power and 30% speed the laser will cut the paper but the slow speed means the edges of the cut are burnt.
Also, the datum point is 'lost' as laser will try and reset to datum by moving off the worktable. I have to stop and manually reset the laser to the start position. What's up?
Any ideas on where the problem is? I have emailed Redsail about the controller settings but no reply of value.
Old 01-31-2012, 04:44 PM
BlueRebel is on a distinguished road
I've just gotten this same machine a week ago. Been running some trials this week with some different woods.
I've not had too many issues yet, everything seems ok so far.
I've been cutting through 6mm MDF so the machine is certainly capable of cutting card. Try turning the speed right down until it cuts, or the power up slightly.
Old 03-16-2012, 01:46 PM
paul87 is on a distinguished road
I don't know if your problem is fixed yet but I thought I'd give my two cents here just incase someone else finds they have the same problem. I believe I read the solution somewhere else to be to change a voltage switch on the machine. The machine may be set to 110V and you need to switch it to 220V. I am assuming this is only if you are not in the USA though. I may be wrong.
Redsail M900 from Sara in China ltlbull Redsail Laser 8 12-21-2011 01:09 PM
Redsail M900 or 6090 iburton Redsail Laser 8 03-03-2011 03:18 PM
Just IN- Aluminum Cutting High Performance Carbide End Mills CDTooling Product Announcements & Manufacturer News 0 09-01-2010 10:01 AM
Bridgeport Interact Series 1 Mk 2 - Expected Cutting Performance? MeTri Bridgeport and Hardinge Mills 1 01-03-2010 06:58 PM
High Performance Cutting kalmah General Metalwork Discussion 3 06-01-2006 08:36 AM
