Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: Redsail X700 arrived
  1. #13
    Dec 2011
    John,
    I was in school last night so I didn't get to play with the laser yesterday but I plan to work on it non-stop this weekend until I get it going.
    Thanks for the link. I've been brushing up on the various issues concerning the soft stop error on this board and the Chinese laser forum so hopefully I will be able to get somewhere tonight.
    I have been starting at the datum. Each successive time I've tried, I move the laser head back to datum and restart both the laser and Easycut. I will post results sometime later tonight after I've had a chance to experiment with it. Thanks again for your help.
    Lonnie
  2. #14
    May 2011
    UK
    Please let me know how things go......I have not connected a pc to the laser yet.....only transferred files via the USB stick......
    For what it is worth I think all your issues are simply software settings issues.
    All the best.
    John
  3. #15
    Dec 2011
    John, would you mind taking a look at these screenshots and compare them to your own settings to see if there are any differences? If it is indeed a software configuration problem then maybe there is some obvious setting that is wrong on my setup.
  4. #16
    May 2011
    UK
    I am not in front of my pc but these look to be the default settings that I have (I have not changed any of these)
    Have you tried transferring a file via USB stick rather than from the pc?
    John
  • #17
    Dec 2011
    No I haven't but the more I read and the more I test my machine I think something is wrong with the axis controller. I'm trying to figure out now how to make sure my firmware for the laser matches the software but it is proving difficult without Redsail's input.
    Now the Y axis is moving up and down instead of just down but the movement limits in both directions are now functioning incorrectly. For movement on either axis, the laser head now bumps up against the the left side for the X axis and the front of the machine for the Y axis.
    I will keep testing and reading and post my results.
    Lonnie
  • #18
    May 2011
    UK
    checked your screenshots against my settings,
    1st screen....my max power is 100% yours is 0%
    2nd screen my pulse rates are both 0.0063500000
    all others are the same.
    John
  • #19
    Dec 2011
    John,
    Would you mind reading my post here concerning firmware versions and see how my settings compare to yours? If your firmware versions are the same as mine then I can rule out that as my problem. I would appreciate it.
    Lonnie
  • #20
    Jan 2007
    Lonnie, we're having the same problem with our M900 (the 60w version). It will cut through if we do the little spot test, but otherwise it only engraves. I can't find anything that would switch it from 110 to 220 (it's plugged into a 220 outlet).
    Where was your switch located?
    Quote Originally Posted by lfe011969 View Post
    John, thanks for your help. I'm just learning myself and I just figured out why I haven't been able to cut. There was a switch in the back of the step-up power transformer that was switched to 110V instead of 220V so even though I had the laser plugged in to the 220V outlet in the front, the whole unit was only getting 110V. Flipping it to 220V corrected that issue.
    Still at issue for myself is the new problem concerning movement on the Y axis. Whatever I've done has caused the laser to only move in the Y- direction. Pushing up causes it to move down. Pushing the Datum button still causes the laser to move back to the origin.
    I'm also getting "Soft Stop" and "Limit Stop" errors when I try to operate the laser. I've tried resetting everything and I've even reinstalled the software. I still get an error during installation but the software still seems to work.
    Lonnie
  • Page 2 of 2 FirstFirst 12
    1. Redsail M500
      By SHADOW042 in forum Redsail Laser
      Last Post: 04-04-2012, 03:10 AM
    2. Redsail Laser Help...
      By ivirscar in forum Redsail Laser
      Last Post: 11-25-2011, 03:31 AM
    3. redsail laser RS6090C
      By VJK in forum Redsail Laser
      Last Post: 06-04-2011, 01:38 AM
    4. New Laser X700 help!
      By harrison1 in forum Redsail Laser
      Last Post: 05-23-2011, 03:22 AM
    5. rhino and redsail
      By LOLO80 in forum Rhino 3D
      Last Post: 07-31-2007, 01:52 PM
