Programming a MPC6515 controller - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Programming a MPC6515 controller
  1. #13
    Feb 2016
    Peru
    Default Re: Programming a MPC6515 controller
    Hello, I´ve just bought the MPC6515 to Gweike Laser (chinese company) but I didn't receive any support from them. Currently I have had many problems with the configurations of the software Lasercut5.3 and the Laser machine. I've had to installed many times the lasercut on my computer because appears the softstop and the pointer laser just runs one point when I press the arrows buttons. Not run forward to the center or to the right or left. To go to the center of the worktable takes like an hour becasue I have to press like a thousand times the buttons.
    The other problem is when I try to cut some 4 mm of wood or 5 mm of soft EVA foam. The machine doesnt cut properly. I dont know which parameters use to get the finished that i want. Engraved and grade engraved is fine, but always I have to cut in the upper right because the machine doesn't run to the center.
    The USB computer are properly connect, I have the dogsoft USD installed avery time, all the connections are OK (I Suppose so)
    I will appreciate any help.
  2. #14
    Dec 2017
    Iraq
    hi CARTOGATE....
    I have the same problem I want to build my own software o control the laser the machine uses Leetro MPC6515 controller
    What I basically need to know, is what information to send to the controller so that I can at least move the laser to the left.
    please help my with any information
  3. #15
    Feb 2016
    Peru
    [QUOTE=dhuha;2126754]hi CARTOGATE....
    please help my with any information[/QU
    My machine is currently work properly, I reinstall tthe program and you have to be carefull with the level of the machine, Must be at the same level.
