- Blowing Fuses?
Blowing Fuses?
I have a couple of the X900 machines and both of them have been blowing fuses.
The first unit melted an e-stop switch and then started to blow fuses to the point the machine wont do more than power up and blow a fuse.
Our second machine seems to have melted the main power switch and is also blowing fuses.
Any pointers would be great!
Re: Blowing Fuses?
Tim, what do you have plugged into the convenience outlets in the back of the machine. These will only handle low amps. Melting the power switch, the power cord fuse, etc have all happened due to trying to run fans, coolers, etc from those outlets. I recommend that you don't use them at all.
- Blowing Fuses?
- You may not post replies
- You may not edit your posts
Forum Rules
