Portable and Separable marking machine BML- FS
Results 1 to 2 of 2
Thread: Portable and Separable marking machine BML- FS
    May 2016
    China
    Default Portable and Separable marking machine BML- FS
    BML-FS is a portable and separable laser marking machine, combined with portable,handhold, table and mini factors all in one machine.
    1.Focal distance: Adjusting by turning up & down stand column manually.
    Lift column transform horizontal motion into vertical movement mainly through handwheel, bevel gear, screw, optical axis , then light path part move up and down
    2.Laser beam path: can be dismantled selectively for marking.
    Fixed by beam path plate and rubber bolt, laser beam path can be separated with machine body. If you want to marking by handhold, just loosen the rubber bolt and dismantled the beam path. Then it can be used as handhold laser marking machine.
    3. Three-in-one power
    Making 5V, 15V, 24V power three-in-one, saving machine space, make machine more smaller and lighter.
    4.Separable working table, putting object easily.
    5.Unique and ingenious design,the machine body is smaller and lighter.
    web:http://www.bodor.com/products/laser-...ines/1306.html
    Attached Thumbnails Attached Thumbnails Portable and Separable marking machine BML- FS-fs-jpg
    May 2016
    China
    Default Re: Portable and Separable marking machine BML- FS
    beautiful
