- Need Help!- PROBLEMS TO CONFIGURATE THE MPC6515 FROM GWEIKE LASER
Hello, I´ve just bought the MPC6515 to Gweike Laser (chinese company) but I didn't receive any support from them. Currently I have had many problems with the configurations of the software Lasercut5.3 and the Laser machine. I've had to installed many times the lasercut on my computer because appears the softstop and the pointer laser just runs one point when I press the arrows buttons. Not run forward to the center or to the right or left. To go to the center of the worktable takes like an hour becasue I have to press like a thousand times the buttons.
The other problem is when I try to cut some 4 mm of wood or 5 mm of soft EVA foam. The machine doesnt cut properly. I dont know which parameters use to get the finished that i want. Engraved and grade engraved is fine, but always I have to cut in the upper right because the machine doesn't run to the center.
The USB computer are properly connect, I have the dogsoft USD installed avery time, all the connections are OK (I Suppose so)
I will appreciate any help.
- You may not post replies
- You may not edit your posts
Forum Rules
