Need Help! Partial cutting problems
Results 1 to 2 of 2
Thread: Partial cutting problems
    Sep 2014
    Question Partial cutting problems
    I have just received my new Redsail X700 with 80W tube and have set it and software up, managing to get it operational. The problem is that it is only cutting a small fraction of the file being loaded.
    Attached are images of:
    1. laser head at origin, focused, ready for cutting.
    2. File loaded on control panel
    3. Message I receive every time I hit start. Full message is "Outrange, if continue?"
    4. The finished cut. Notice it is a single vertical line.
    Having tried some other files it feels like the laser origin is completely wrong in regard to origin of the file. It's almost like it thinks it is started from the top right corner, and therefor only managing to cut the rightmost part of the file. (No photo, but when trying a circle I get only the right most portion of the circle resulting in an arc, looking like a ")"... )
    I've triple checked the origin is set to top left corner. Really need some help trouble shooting this as the cutter is useless as is.
    Software is AutoLaser 2.0.8
    TL-403 Engraving and Cutting Control System
    Any and all ideas welcome thankyou!
    Attached Thumbnails Attached Thumbnails Partial cutting problems-03-outrange-message-jpg   Partial cutting problems-04-finished-cut-jpg   Partial cutting problems-02-file-loaded-ready-cut-jpg   Partial cutting problems-01-cut-origin-jpg
    Sep 2014
    Default Re: Partial cutting problems
    UPDATE:
    If I manually start the cut from the right hand side of the bed it will cut the whole image. Problem is it is cutting a mirror image of the file, so the laser head is going left when it should be going right.
    No idea how to fix this, but will update any progress on the issue in case others have a similar problem down the track.
