- Setting up machine
Setting up machine
I am new at this and need some help setting up my unit. I have a Red Sail x700. and the info on setting this macine up is rather limited. Am I to assume that you plug the water and air pump also the blower to the outlets on the back of the machine? There are three outlets on the machine. Also does anyone know the amperage of the machne? I have an electritian that is going too wire up a storage unit for me and is asking for the amperage of this unit. Should I go with an 220 or a 240 volt breaker if I wire directly without the transformer? Will this machine work on 60 hz or will I need the transformer supplied with this unit to go from 60 to 50 hz?
Thanks.
Re: Setting up machine
Hey Astro, aka tralfaz.
No help on laser issue, just wanted to say hi.
I worked at both Cogswell Cogs and Spacely Sprockets.
And know what its like to be v.p.
md
Cool! Just got a patent on a product. Starting my own business, v.p., v.i.p., secretary and janitor! LOL!
- You may not post replies
- You may not edit your posts
Forum Rules
