- Leetro Firmware update
UPDATE:
I believe I have found the problem with my laser. After looking carefully at the DLL files contained within the Easycut installation folder, I noticed a series of DLLs named "mpc05ls_XXXXXXXX.dll" where the XXXXXXXX is the version number made up of two digit numbers for each number. Since I know the hardware version is 4.1.2.3 I checked the version of the file named "mpc05ls_04010203.dll" and sure enough the version displayed in the properties is 4.1.2.2 and not 4.1.2.3.
I've already emailed Redsail but I'm not sure when of if I will hear back from them. I also don't see anything on their website about downloading dll files. Does anyone know where I can get a hold of the correct dll? Since the Leetro controller card is used by many laser companies, can I just use the dll from another laser manufacturer?
Lonnie
I don't have a PC in the room with my X700......will get hold of a laptop and check mine.
John
Thanks John, I really appreciate it.
On a side note I found out why Redsail hasn't gotten back to me. They are closed until February 1 for the Chinese New Year. Just my luck to get my laser at the same time the company is closed for 2 weeks, lol.
Lonnie
Hi lonnie, on the software, to get files to the machine do you press download then does it open the standalone file manager where you download currant file? and is there a "download CFG" if so try pressing it, the laser should beep. Normally if you have a mismatched dll the machine tells you. Have you set the table size up? Hope this helps a little
Cheers Simon
Hi Simon,
I do use the standalone file manager via the download button and I do receive one beep when I download the config. I have set my table size to 700 X 500 within the software but it is still not working.
I've read that a mismatched dll will indeed give you an error message on the display but I'm wondering if the file name of the dll has anything to do with it. If it goes by file name then it is named correctly but checking the properties of the actual dll tells me that the version is different. I don't know.
I've been busy with school this week so I plan on staying in my garage this weekend until I make some kind of headway with this. I will report any findings. Thanks for your help.
Lonnie
- You may not post replies
- You may not edit your posts
Forum Rules
