Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > RC Robotics & Autonomous Robots
RC Robotics & Autonomous Robots Discuss Robotic construction that pertains to CNC hardware and electronics here!
Old 07-26-2007, 08:05 PM
dondeaida is on a distinguished road
speed control with MIDI servo controller?
Hi all,
There are a few servo controller boards that use MIDI interface such as the one at
http://tech.yostengineering.com/servoFolder
And for this type of boards, ordinary MIDI sequencer software (yes, a music software) is used to control the board instead of dedicated servo control software like robo-ware etc.
Now I have some MIDI knowledge and I can see that it will be no sweat to turn on and off the servo and rotating the servo to desired position with MIDI sequencer.
However I do not see a way to control the rotation speed of the servo with MIDI sequencer.
Anyone of you successfully controlled servo speed MIDI way?
I am especially interested in "timed" way of controlling servo speed. It works like this:
you give a movement and specify the time in which this movement should be completed, let's say 2 second, then the software calculates all necessary variables (such as velocity etc.) and completes the movement on 2 second mark.
I found out that most SSC boards like MiniSSC ll, SSC-32 have this function. I wonder this is possible with MIDI sequencer....
Well, Thank you for reading my post and have a great day!
[IMG] code is Off
My New MIDI-Router Design - Production has started! widgitmaster CNC Wood Router Project Log 359 08-14-2011 12:47 AM
Speed control (not a servo amp) for BLDC motors? Zumba Servo Motors and Drives 1 06-19-2007 08:05 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
speed controller? slp_prlzys General Electronics Discussion 10 09-04-2004 03:40 PM
Speed Controller recommendations? paulried DIY-CNC Router Table Machines 2 05-13-2003 05:39 AM
