Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > RC Robotics & Autonomous Robots
RC Robotics & Autonomous Robots Discuss Robotic construction that pertains to CNC hardware and electronics here!
Old 04-27-2007, 06:04 PM
r3dsk4r3 is on a distinguished road
Any clue about these motors?
I bought these motors from ebay, and have been having some trouble figuring them out... I've googled the serials, but to no avail.
They have 8 wires: Black, Brown, Salmon, Red, Yellow, Green, Purple, and Blue.
They were made by Shinanokenshi Co,Ltd Japan.
The label has three codes on it.
78-8057-3185-4
DR-4312-501
22351 (looks like it was stamped, not printed)
I've tested them with a multimeter, and based on the resistances I can group them into 3 categories...
Brown/Salmon/Red/Yellow: erratic and temporary resistance when tested with the black wire. Infinite resistance between members of the group or the GPB group.
The Black wire: erratic (30-150ohm) and temporary resistance when tested with the BSRY group. Infinite resistance between the GPB group.
Green/Purple/Blue: Infinite resistance between the other two groups, but 1.9 ohms between members of the GPB group.
I'm really at a loss here.. I would really appreciate any help.
Old 04-27-2007, 06:26 PM
Al_The_Man's Avatar
At a guess I would say you probabally have a DC brushless motor, the three with the 1.9 ohm could be the stator and the other 5 could be Black & Red = common & + supply, The other three commutation for the armature.
As they show high resistance, I would put 5v across the BR and put a volt meter on black to any of the other BrSaYe, rotate the motor by hand and see if a pulse occurs, if ~ 2p/rev then these are commutation, if much more frequent then could be encoder pulses.
If you confirm that they are commutation, there is further things you can do to phase them correctly.
Old 04-27-2007, 08:08 PM
the auction said that they were stepping motors.. are they? if not they are getting returned. they certainly dont seem to be.. thanks for the info though.
Old 04-27-2007, 09:32 PM
Al_The_Man's Avatar
They do not appear to be, from those readings, if you confirm the pulse as I mentioned it may clinch it.
Old 07-25-2007, 10:57 PM
ejserv is on a distinguished road
Did you have any luck with your motors?
Ed Service
[IMG] code is Off
Clue less and looking for some answers. Smitty911 Gecko Drives 47 03-12-2008 09:20 AM
How hot does your motors get? alexccmeister Stepper Motors and Drives 2 04-17-2007 11:53 PM
PWM for AC Motors? vacpress General Electronics Discussion 34 03-07-2007 07:42 PM
An So it Begins...Building my first cnc router. No Clue, but what does that matter :) InventorJohn CNC Wood Router Project Log 44 01-17-2007 10:22 AM
New Guy, No Clue, Router Advice?? meyer712 DIY-CNC Router Table Machines 3 12-18-2005 08:07 PM
