Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > RC Robotics & Autonomous Robots
RC Robotics & Autonomous Robots Discuss Robotic construction that pertains to CNC hardware and electronics here!
Old 02-18-2007, 07:57 PM
keebler303 is on a distinguished road
how to drive this robot
If I were to buy this robot without controls, could I use gecko's or some other reasonably priced servo controller to power the motors?
Does fanuc use standard motors and encoders that could be interfaced to generic drivers?
It is a Fanuc S700.
http://www.autotech-robotics.com/Used/Fanuc-S710.jpg
Matt
Old 02-18-2007, 11:17 PM
Zumba is on a distinguished road
No. Geckos are for DC brushed servos. The robot uses AC brushless servos. Even if they were the same type, the Geckos would be way too small.
Old 02-19-2007, 01:12 AM
walter's Avatar
Gold Member
walter is on a distinguished road
Talk to Zone member Xerxes- he's building AC drives
http://www.cnczone.com/forums/showthread.php?t=14477
Old 02-19-2007, 05:19 AM
svenakela is on a distinguished road
You should check Rutex as well. http://www.rutex.com
Regards,
Sven
Old 02-19-2007, 06:59 AM
Looks like this will be out of my budget. I thought it would be cool to have a robot to play with but drives for 6 axis looks like 2 much just for a toy.
Matt
Old 02-19-2007, 03:33 PM
Where is this robot located? Is it for sale?
Old 02-19-2007, 03:56 PM
yes, on ebay.
Cincinnati Ohio
1,000 for just robot, no drives, includes cables and motors.
Matt
Old 02-19-2007, 06:46 PM
walter's Avatar
Gold Member
Hey, isn't that the robot from GM Super Bowl commercial?? The one that was fired and then jumped off a bridge?
LOL, No wonder it has no electronics...
http://www.youtube.com/watch?v=UQKk3PI-DW8
I wouldn't buy that if I were you...check out the movie 'Hardware'..
Name:	GM robot.jpg‎
ID:	32107   Click image for larger version
ID:	32108   Click image for larger version
Old 02-21-2007, 03:04 PM
ahren's Avatar
ahren is on a distinguished road
Even if you can get drives for the robot, the kinematics for this sort of device are non-trivial. Unlike a gantry, you can't just drive to the desired X, Y and Z -- you need to go through the coordinate transforms for each joint, which requires you to know the dimensions of the joints as well. Without the controller for the robot, I don't think you'll have much fun with this one.
Old 02-21-2007, 04:25 PM
There are open source/freeware softwares for driving robots. Do some googling.
Regards,
Sven
  #11   Ban this user!
Old 02-21-2007, 08:30 PM
If you want to move in a straight line using simultaneous 6 axis movement, no not trivial at all. If you can get an old industrial robot functioning and be able to learn how to do some really cool things as you go, I see no problem. If I bought it I would like to get it running with mach and then just start playing around, purely fun and hobby value, not like I am gonna start welding up cars with it or anything.
Matt
  #12   Ban this user!
Old 02-22-2007, 12:23 AM
ahren's Avatar
Not trying to rain on anyone's parade -- certainly you could use one of the open source programs available if all you want to do is mess around. Seeing as how this is CNC zone, I figured the poster might be interested in tool paths, or at least going to defined XY positions. Without knowing the lengths of the joints, the accuracy you would be able to achieve in either case will be fairly limited. I have experienced just this problem with a demo SCARA robot, which is far less complicated than this beasty. All that being said, the point still remains that robots are just plain cool .
[IMG] code is Off
What robot? ToyMaker RC Robotics & Autonomous Robots 1 05-29-2012 09:40 PM
CRS Robot Arm pestana1957 RC Robotics & Autonomous Robots 0 01-26-2007 02:04 PM
CNC to Robot GT_racing G-Code Programing 0 05-24-2006 08:18 AM
Robot Retrofit keithorr CamSoft Products 0 09-26-2005 02:44 AM
robot arm help magicruss RC Robotics & Autonomous Robots 5 03-01-2005 11:06 PM
