PNP Software
Results 1 to 7 of 7
Thread: PNP Software
    Jan 2008
    Spain
    Sep 2006
    italy
    Thanks for the link. I have used the dispenser SW from this guy too.
    Jan 2008
    Spain
    Hello Nisma
    can you give me the dispenser SW
    I cannot find the link
    Thanks in advance
    Regards
    Sep 2006
    italy
    I think it's this:
    http://www.dockerty.co.nz/software/dispense.zip
    I have downloaded it from madell site, so if it's not, tell me and i search
    the downloaded file. It's a software that read in the gerber file and from that it
    generate the dispenser location and time/type of dot to apply. I use it on CNC.
    Do you use the PNP sw. I have tested it with EMC2 instead of the deskcnc controller.
    Some issues with vision on tray feeder related to uncorrected camera distortion and because that
    relaxed 0.7 correlation. For real usage, i suggest replace the vision code with opencv and undistort the
    camera or at least the roi using the relative function from opencv. OpenCV support for delphi/lazarus
    is available, so it's just adding camera correction support and using the better optimized
    opencv functions, not because different algorithm, just because faster.
    Jan 2008
    Spain
    Hello Nisma
    Thanks a lot ., I´ll check it this night
    About PNP , yes I used it with DEskcnc controller
    I make a machine and now , all mechanics perform quite OK , and yes now I have some issues with camera (for placement parts )
    I ´m working hard to find the way
    Regards
    Jul 2011
    Croatia
    Would anyone be able to recommend some free software for pick and place machine, I started to make SMD pick and place machine that had a working area of 250 x 350 mm, with 40 SMD feeder?
    Do you have some program free that could manage SMD pick and place machine via LPT or USB port, and that can add a certain number of feeder and the feeder entered for each parameter X, Y, Z axes ?
    Regards
    My Z axis :
  7. #7
    Jul 2011
    Croatia
    Come on guys, you're not make a machine and you do not have any free program for test, I really need a program to pick and place machine, which is free, does not require a visual inspection, I need something basic where you can enter the coordinates of the feeder and enter parameters head .
    Please I need help
PNP Software
PNP Software
