Need Help! panarobo upload/download software
Results 1 to 12 of 12
Thread: panarobo upload/download software
    Jul 2009
    Default panarobo upload/download software
    Hello to all,
    I have been asked to back-up the part programs on a panasonic panarobo AW005 robot and that seems impossible without the software......
    After contacting panasonic I found the machine is no longer supported and the software is not available. There is a windows based software out there that I need and if there is anyone out there who has it, would it be possible to get a copy of it???
    Thanks in advance.
    Jul 2009
    One would think with all the robots out there there would be some software available.
    Anyway, it is now a done deal, progs are backed up. Enjoy the panarobos if you have them, they last for years.
    Null modem cables pinout and wiring @ pinouts.ru
    this cable works
    Jul 2011
    Us
    Default Please share info!!!
    Hello, I have just acquired a Panarobo vs25 with a Panadac 385 controller. Like you, I have found close to NOTHING on Google in terms of documentation or software. The door of the Panadac controller has a db25 port for uploading/downloading programs, but I am unsure what to do with it without the software.
    So here go the questions:
    How did you back up the programs without the software?
    Is there any way to manipulate the robot without the panasonic software aside from the teaching pendant?
    Any idea on where to obtain the software or how much it costs?
    What type of input does the controller expect? G codes? I read somewhere that the code was visual basic-like, however I am unsure if this is the case.
    Once connected, did you use puTTY or other terminal emulation software? If so do you have any tips such as useful commands or how the terminal is presented?
    Truth be told, I do not yet have access to the machine, but I would like to be prepared as I will have a window of around one month to attempt to get it functioning before I have to fly out of the country. I am also amazed at the lack of documentation and software on behalf of Panasonic.
    Thank you,
    Vittorio
    Would it be possible to bypass the controller
    Jul 2009
    Default panarobo software
    Vittorio88,
    I have the software for the aw005, which may work for others. also the cable pinout, have to get that later today. I will send what i have..... fairly straight forward process to upload/download.
    Let me know where you need to have it sent.
    Oh, FYI..... I cant seem to find anything on VS25, do you have any more info on what it is you have......
    Jul 2011
    Us
    Default Thank you!!!!
    There is a special place in heaven for people like you!!!
    My email is vittorio88 at msn dot com
    I will get some images together and post them in addition to technical specs later today.
    If the file is too large I can set up a server for you to upload tomorrow.
    Jul 2011
    Us
    Default More info
    Ok, so I butchered the model number, the correct one is ks-v25. The controller is a PanaDAC 385s.
    It appears to be an educational robot.
    I would still appreciate the software, because I have no where to start.
    I have included images of the robot, the controller and the teaching pendant.
    Thanks,
    Vittorio
    Attached Thumbnails Attached Thumbnails panarobo upload/download software-photo-1-3-jpg   panarobo upload/download software-photo-2-3-jpg   panarobo upload/download software-photo-2-2-jpg   panarobo upload/download software-photo-5-3-jpg
  7. #7
    Oct 2011
    canada
    Default Panarobo soft
    Quote Originally Posted by 323ci View Post
    Vittorio88,
    Were in the same boat. Is there a way I can get a copy?
  8. #8
    Jul 2011
    Us
    Default Software
    If I remember correctly the software was incompatible, but if you want I'll send it to you. Send me an email to (myusername)@msn.com, and I will reply with it as an attatchment.
    You need Dosbox to make it work.
    Do you have any other info, as to how to program the robot with a PC?
    I also need to reset/adjust the servo encoder, because the servos have a nasty jitter when the arm moves.
  9. #9
    May 2016
    Malaysia
    Default Re: Panarobo soft
    Hi, I have just acquired a Panarobo vs20 with a Panadac 380 controller. Like you, I have found close to NOTHING on Google in terms of documentation or software. The door of the Panadac controller has a db25 port for uploading/downloading programs, but I am unsure what to do with it without the software.
    Any idea on where to obtain the software and manual
    Thank you,
    Resh
  10. #10
    May 2016
    Malaysia
    Hi Good Morning any updates
    Resh
  11. #11
    Default Re: panarobo upload/download software
    Hello, I have Panasonic robot model VR-008A. The controller box have RS-232C port. I have RS-232C cable but I don't have the software. Can you send to me the software? Thank you.
  12. #12
    Nov 2017
    Hi Vitto, Can you send me the pana robo softwaree too please i have a Pana robo vr006 and need to extract the program from backup purposes. Please and thank you for your time.
    Quote Originally Posted by Vittorio88 View Post
  13. #13
    Aug 2015
    Default Re: panarobo software
    Hi, I have also been looking all over for the software and have had no luck.
    I have robots vr005 c2 and I need to backup the programs.
    could you help me by sharing the software you have to see if it works on the robots I have.
    thanks, in advance.
