| PTC Pro/Manufacture Discuss PTC Pro/Manufacture software here. |
| DOGLEG RAPID how can i show dogleg rapids in pro e?rapids go in a straight line now but at the mach they angle to the shortest 1st and then go the rest in a straight line. thanks mark |
| Wow, that's a tough one. Probably be easier to tell Mach to interpolate the rapids so that they are straight line motions. In instances where the tool may crash, you could replace the G00 with a high feedrate G01. I have had this problem once in a while, usually when drilling bolt circles, but the easy solution is to use a higher rapid clearance plane so that the tool clears the clamps between holes.
| Rapid to (# set by Parameter) What's yours? | Scott_bob | G-Code Programing | 8 | 07-13-2009 08:05 AM |
| MDI rapid vs jog problem | Chris64 | Mach Software (ArtSoft software) | 4 | 03-08-2008 10:34 AM |
| rapid speed | contractdesign | Bridgeport and Hardinge Mills | 6 | 06-04-2007 10:23 AM |
| G-Zero by Rapid Output!!!!! | tobyaxis | General CAM Discussion | 0 | 02-04-2007 11:16 PM |
| Rapid moves G00 | dicksonhof | Mach Software (ArtSoft software) | 9 | 11-07-2006 10:21 AM |
